protoj ·
If you have topped up your phone before the 12th August and you text
THANKS to 26929, Tesco will credit your phone with £5.00
It is because they got No.1 for Customer Satisfaction. It may take a while to come or it could be straight away.
Happy free £5 everyone.
Offer ends Sunday 15th August.
Phil
