Glastonbury 1st August 2pm
Hello All,
The next meet is going to be at Glastonbury at the Wagon and Horses Inn.
Address: 113 Wells Road, Glastonbury
Postcode: BA6 9AJ
Time: 2pm
Google Maps: View
I hope to see you there :)
1. Murt
2. Funkysi
3. Legrath
4. black-zed
5. matty daak
6. yewcheck
7. Russ
8.
9.
10.
Edited by murt
  • Replies 32
  • Views 793
i may try and make it just got a slight water leak issue i need to try and sort first, anyone got a conzult or data scan they can bring?
I think Murt has a Conzult, if you ask him nicely. :yes:
Checked with the GF and not got anything on this sunday so i'll pop along, hopefully sans-hangover, lots of live music around glastonbury town pubs saturday night
cool will be good to catch up i just need to get this damn turbo pipe replaced it's decided to start letting off pressure when car is either slow traffic or static
MY lead is playing up mate, im not having any luck in trying to get it reading anything, but i will bring it anyhow, just to see if i can get it working.
If i can get down there you are welcome to use my lead! [may be away that weekend camping........weather permitting if not i will be there]
Edited by yewcheck
cool thanks guys well after several hours and various pairs of long nose pliers in use i managed to replace the drivers side turbo hose so thats both sides of the bypass done now so hopefully no more water problems it turned out the metal spring clips had eaten into the hose and was causng the leak thats both sides within a week of each other then developed a misfire (have started thread on it) as after swapping coil packs then plugs around it all sprung into life
I'll be there, if my turbos have'nt completely given up the ghost by then! If not then I'll commandeer a volvo ;)
1. Murt
2. Funkysi
3. Legrath
4. black-zed
5. matty daak
6. yewcheck
7.
8.
9.
10.
Sure. I'll be in the Daily driver though.
You're welcome to ride in my Z.
Will you be taking your Zed ? :ohmy:
Get round mine for 1.30 then. You can either walk or leave your DD at mine.
i'm hoping i'll be in the zed but i'm chasing my tail at mo replacing water pipes just had the one at the rear of the passenger side turbo fail ( and what a pig it was to do) put it all back together and one of the heater hoses has now got a pin hole leak so i'm off for more pipe tomorrow to bypass heater matrix and replace the small pipe from the drivers side turbo
Walk!? Walk!? ...I'll park at yours :) Ta
