protoj ·
My partner has a 2004 Renault Scenic 1.5dci, when she went out yesterday the clutch pedal stuck down and it would not go into gear.
Now the clutch pedal stays down on the floor and you have to pull it back up and it will not go into any gear.
At first I thought the clutch might of gone, but now I am thinking it might be something like the slave cylinder?
It was running fine prior to this, has anyone got any ideas what might be wrong with it?
