Hi,
Quiack question, blue smoke on start up and over run, what can cause this turbo seals maybe?
And is it a engine out job to get the turbos off?
cheers Mark
I have the same problem except only on over run, if i dip the clutch when slowing down no smoke at all, its fine from cold aswell, only ever when i back off the throttle, even just sensible driving
Smoke on over-run will proberbly be piston ring wear, had this on my 300. If you let the engine naturally run down from, say, 5000 rpm to 1500 rpm and the old smoke bellows from the zorts at approx 3500-2500 prm, then piston rings for sure. Sorry dude, rebuild time. Contact "jimmer" on here, he rebuilt my zed, top bloke for it.
Al.
Thanks for the reply mate. lucky for me it was a car that is was looking to buy, but someone got there before me.
cheers Mark
Al.
Doubt i will be contacting jimmer, according to him i'm the main reason mot testers have a bad name :whistling:
Time for a compression test methinks, just had an engine fitted.
