plenum off with engine still in?
I just wanted to check before i did to much more. There are two metal pipes which come out of the bottom of the plenum, how the hell do you get them off it seem imposable to get to?
they are pretty awkward to get to, but if you take everything else you can possibly get off, including the main plenum bolts, you can lift it a little bit, which does help quite a bit, i think i lifted it as much as i could, then wedged a bit of wood somewhere to keep it there whilst i tackled those pipes... hth.
is there a specific size need for the nut/s under the plenum?
