Air fuel ratio gauge
Just wanted to confirm how to fit a AFR gauge as the Z has two oxygen sensors.
Do i install a manual switch to toggle between the left & right sensor as the gauge only has one signal input?
Cheers.
Erm if thats possible great idea....But otherwise i think you would need 2 guages or a guage that can read and display 2 readings.
My setup ive got 1 guage reading the right handside and a multi guage thats linked to my AEM ecu that reads the signal off the left handside.
Thanks for the reply mate. Just been on a websight that sells gauges and there manual states that it will be ok to install a switch in between the two sensors.
I used a two way toggle switch wired to both o2 sensors. Allows me to switch between both banks without any problems :)
