Lost Locking Wheel Nut.
i have lost me locking wheel nut key!:cursing: the pictures show the locking nuts any help or advise as to how i can get them off would be gratefull.
dan.
Edited by dannzx
halfords do a locking nut removal tool they are about £15 i had to have one removed as rest had already been taken off car and my local tyre centre had a removal tool and did the job for me
ok thanks will give them a try.
explosives mate :w00t:
sorry its bin the wrong type of day!
dan.
If theres enough clearance you may be able to force a socket onto it with a lump hammer, but you could cause damage so may be better to go down the route of getting it done properly :)
If you know who made the locking nut you could contact them for a key - I had to That once before and they were very helpful about making sure I got the correct fitting Key
Yup I had to do this a few months ago. If you still have the packaging then there should be a serial number and they'll be able to send you a replacement.
thanks for the replys, their is a old saying! "there's always one" managed to get 3 off but as you can see from the pic the damn top came off once got a grip of it!:pinch::cursing: went round to the garage i use and he reckons an air chisel!!!!!!!!!:eek: look like i am going to need a near as possible key to get the last one off.
dan.:smash:
tighten the other 4 bolts up as tight as you can so it will at least relieve some pressure off the bolt, DONT use an air chisel,
at the very last resort you could knock out the other 4 studs, then turn the whole wheel to loosen off the nut,
you may have to buy new studs though but im thinking its the least amount of damage
:yes:
well the other key didnt work so going to drill the stud out and hopefully it should either just pull off or snap off!
dan.:smash:
Had this problem a while ago on my sons car. I got a length of steel pipe slightly larger dia. than the locking wheel nut. Then welded the pipe (from hte inside to the nut, I had already drilled a large hole in the other end of the pipe and put a breaker in the hole then just undo using breaker bar simples! Repeat and continue on all the remaining nuts, just cutting off the old fecked wheel nut welded to the bar.
hth
hth
Great minds! I had to do this on my old car. And on 3 out of 4 as well. Worked a treat.
its off!!:clap: started drilling it out progressively getting bigger finished it off with a good quality 14mm drill bit came out a treat in the end! need a rear stud now.
dan.:biggrin:
Great news Dan! See you for coffee and cakes tomorrow!
yep teeth are better now!!:blush: someit soft and sticky me thinks see you later!!:yes:
dan.:thumbup1:
