there are two oil coolers infront of my rad the larger of the two can it be moved without any impacations and the tiny one in front of that dose is actully do anything its so small? because i need that space there tacken up.
AC rad and Oil cooler / auto box cooler.
You can move them anywhere, where is still enough air flow as long as the pipe work stays intact. Removal on the other hand is a different story unles you are doing away with the aircon.
I know what you mean about the little one in front of the oil cooler i have it on my UK spec TT but not on the Jap one not too sure what it is for allthough i have a manual and an automatic but i wouldnt think it is anything to do with gearbox being all the way at the front
UK has at the front :
Engine oil cooler (Large)
Autobox oil cooler (if Auto)
PAS Fluid cooler
Jap has at the front :
Small Engine oil cooler (Small)
If you are moving them (to fit a FMIC?) , then as long as you move them to somewhere that gets good airflow from the front still...ie, where the stock SMIC's usually are, then its fine.
PAS Fluid cooler
Ah gotcha its PAS cooler then :)
Right minea a uk tt and ive already taken out aircon so im left with the oil cooler but isnt the power steering cooler a bit of over engeering do we realy need it over here?
My Jap TT hasnt got one and im sure there are plenty of Japp TTs over here without them that work fine. IMO its just another system that can be deleted
