Maf Required for testing, Can you help?
hi, i have a 90 n/a 300. is there any one in the andover ish area that has a good air mass meter that i could try. i have got a new unit from ebay and it has changed the problem (would not rev past 2500) to a missfire and what appears to be over fueling at 2800/3200. no codes in the ecu now.
Did you get the new ones on Ebay that cost under £100? If so I'm afarid they're known for over fueling :(
I have a spare good working maff, where in hants are you, im only in Worthing along the A27, if you can get the car over to here next saturday, i can give it a once over, ie check other things, tps, connectors, ptu etc etc
work some magic,
stu
thanks for the input, maff cost 70 quid delivered ! should have know better, will try to return unit for exchange, if no joy will contact sussex stu and try his good unit.
