anybody know an answer to my question?
as some of you are aware i am going to be removing most of the common things like egr, aiv etc and as i dont have hicas i wish to remove hicas unit in the engine bay..
i am also fitting the clutch for my manual conversion.....
apparently i need some braided pipe and some of which has to have a no return valve (i think thats what its called)
can anyone recommend how many of these i should first start of buying to cover the manual gearbox conversion and the relocation of the PAS pump and removal of the egr, aiv etc.
i would prefer to get a few up front to save delivery costs but have no idea what i need.
if it helps i can provide a list i wish to do to the engine bay so that someone can make a rough estimate to what i want :)
list is:
* Re-route PAS to rear of engine
* Remove AIV, EGR valves and perform upper plenum perform Water Bypass)
* Install clutch pedal and the part that stores the fluid???
i know im not clear but with the re-route and things i was just wondering if i need new pipes
Here are the deletes done on mine http://www.project300tt.com/2010/03/15/my-top-ten-300-zx-deletes-and-weight-saving-tips/
Also relocating the PAS pump http://www.project300tt.com/2010/03/22/relocating-power-steering-resovoir/
You can use your existing no return valve m8 no need for a new one.
You will need some decent braided hose, I got mine off ebay but they do sell some thin crap stuff on there so make sure its the fuel pipe stuff. Also Jubilee clips and a few P clips, make sure you buy real jubilee clips they are a million times better than the fake ones. Sorry just read you are doing a conversion so I guess you will need a no return valve..
Edited by madmax
