pcv valves and pipes
next on my list of things to do with my zed is to change the pcv valves as i have a bit of smoke at idle from the passenger side bank which appears after a couple of mins of idling . can the old valves and pipes be cleaned up or do they need to be replaced . if they need to be replaced can anyone recommend a place to buy from . also is it an easy enough job to do .
not worth cleaning them up (tried it!:blush:)just as well put a new set in and be done with it, have a look in traders section.
dan.:cool3:
As stated above, no easy way to clean the old hoses - plus they usually perish when removed from the engine anyway ...
I can supply a new set of PCV valves and 5 hoses for £95.00 incl. delivery.
Regards,
thanks for that mate . cars in the paint shop at the moment being made all beautifull . will contact you at later date . cheers
