Hello there all members,, im looking for a set of disc and cant afford a brand new set at the minute, as out of work so has anyone got any used discs...poss or no where to get them rite cheap,,,pls help if u can thanks all..............
sorry just the front ones i was just told i need not back ones ........thanks again.....
Do you know the size of discs, as the earlier NA's apparently have a narrower disc than the TT's
ย
I got discs of ebay that were reasonable, failing that thompson's, back o hill stirling are a motor factor that are good, but because your car is an NA they might not be able to help.
ย
I have the old TT discs that I changed, problem is they have been outside a while and have a lot of surface rust. They may clean up but I doubt it.
yes pls i said to my m8 and he said he would try wet and dry them,, so be great if i could have them,,thanks.
ok I will look them out tomorrow night when I get back from work,
ย
I'll give them a clean with the brush attachment on the angle grinder. Cut down on some of the rubbing :)
ย
Think they may be too big for your motor, but suppose its worth a try.
ย
Are you still in Langlees? I can drop them off if you let me know where.
Ok they are cleaned up, came up better than I thought they would.
Just let me know when and where to drop them off
thanks very much,, a stay in grangemouth at the minute,,,my number is 07905567087 just text or ring and i will phone u str8 back,thnak u ........
