revs fluctuate
Hi guys just noticed this in the last two days,when driving in top gear,by the way car is an auto,say the car is steady at 2500 rpm all of a sudden it will shoot up to 2800,when this happens of course i can hear it in the revs,dun the same at 3000 rpm jumps up to 3300,and does this oppisite way aswell high rev then drop a wee bit lower,have only noticed this in top gear,all pipes are tight and no air leaks. Any clues. once again any help would be appreciated.:biggrin::biggrin:
Mmm... sounds like the torque lock up on the autobox is dropping in and out, could be a throttle position sensor error, or could at worse a gearbox issue hope its not.
Get the tps checked out, and do an autobox diagnostic, the link below should help.
http://www.zedworld.co.uk/wizzj.html#auto_box
Jeff TT
Jeff TT
Thanks for that jeff il give it a go and let you no.
