Ecu's Relay's & Fuse's
Thought I would start a thread on identifying and the location of all the Ecu's Relay's and Fuse's, I have taken pictures of the one's that I have if people can ID them and put a location to them that would be great, please feel free to add to this list, if peeps think this is usefull maybe it could go into FAQ.
Edited by 300_zedx
1 Engine ecu
2 Auto box ecu
3 Fuel pump ecu
4 ABS ecu
5 Power steering ecu
6 Ariel timer module
7 Cruise control ecu
8 Timer module and fuel pump relay
9 Rear light control ( thanks groover )
10 erm this ones familiar
11 Window lift module
12 Single pole relay( blue) Double pole relay (brown ) change over relay ( black)
13 Hazzard lights flasher
14 Relay
15 Starter motor inhibitor relay
16 TPS
17 Fuses ( green ) Battery thermal link ( Blue) reset fuse ( Red )
Jeff TT
Edited by JeffTT
Thanks Jeff and Graham, when you find the time could you put where they are situated in the car:thumbup:.
cheers Paul
Great idea putting these pictures up! Some numbers on them too might be an idea just for ease of use! :bow:
Here you go.
Jeff TT
1 Engine ecu
Passenger foot well
2 Auto box ecu
Passenger foot well
3 Fuel pump ecu
Behind passenger side rear quarter panel
4 ABS ecu
Behind drivers side rear quarter panel
Passenger foot well
Behind drivers side boot panel
Passenger foot well
Behind drivers side footwell panel
Behind drivers side rear light cluster (outer)
Behind drivers side door panel
Black fuse box under bonnet passenger side inner wing
Above brake pedal
14 Relay
Black fuse box under bonnet passenger side inner wing + rear of fusebox in drivers footwell
Behind drivers side front wing (at rear up high)
16 TPS
Left hand throttle body
Slim fuse box drivers side inner wing by brake master cylinder
Thanks Jeff. Number 9 chime box???
Paul
Well I thought that but the chime box has three cables???
Jeff TT
It does, but looks like one wire has been cut to stop the speed chime, but keep the light chime.
I thought you were joking when you said this ones familiar, indicating that everyone knows what that is lol
The missing cable threw me..honest guv :rofl:
Jeff
:tt2: Now in the faq section, under general faq's.
If anything beneficial is added to the thread info, i will include it in the faq section.
Top job groover, good suggestion 300zx_zx
Jeff
