Replacing speedo
Hi all!
I am thinking of buying a new spedo. The one that Z centre has for sale. In iridium blue! It will match my rpm clock and will replace the faulty standard one..(works only when warm).
My question is regarding calibration...where do I need to go in order to get it calibrated?
Any sugestion...
Cheers!
Luke should give you all the info you need for fitting and it must have some form of calibration adjustment on the back of the dial, again Luke will know.
Good luck
Good luck
Thank u! I will contact him!
You can calibrate the standard clocks, there is a write up somewhere, will try and find it.
The one lorenzo is going for is digital and non standard
Apparently luke is only registered user so I can't pm him...
I will call tomorrow z centre and ask for more detailes!
Hi all!
Any sugestion...
Cheers!
that looks brilliant where does it go how does it work???
It replaces your existing speedo clock.
