headlight adjustment ?
Manual shows two adjustment screws, To move up/down, L&Right, on each headlight, States adjust dipped beam ist, Then gives info on adjustment to main beam, no info on screws for this ? same screws ? What to do, adjust main or dipped, only ? Recently fitted H I D conversion, causing a bit of upset to other road users.
screw? I thought the Z had like a little gear (with cogs) that you had to turn to adjust the
headlights ?
Hi,
There are four adjustment screws/nuts, two for each beam, one horizontal and one vertical…… sorry tying not to be patronising…
You can see the first photo here shows the back of the unit clearly showing three of the grey adjustment units and the fourth near the top of the low beam is a shaft…
http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.346
this shows the light unit in more details with pictures of different adjustment screws and their replacement / repair.
http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.349
finally the parts list showing a diagram of the light unit, not clearly showing all adjusters.
http://www.300zx.lv/catalog/?gr=E&sec=260
you might have the damaged cog issue as well…. You’ll soon know when turning the adjusters dose nothing…lol…
Edited by Medallion Man
