NA flywheel on TT engine
....in order to avoid fouling and to increase bhp (in theory) will it fit?
What is fouling what, plugs? or something rubbing on something else? How would it increase BHP?
the tt flywheel will foul the box at the bottom, easy enough job to grind it out so it fits only i was thinking why not use the lighter NA flywheel too avoiding any rubbing or box modification (the na flywheel is smaller, and i assume lighter)
Marginally lighter....nothing in comparison to a Aftermarket lightweight flywheel though.
Trouble is you would also have to use an NA Clutch (uprated) to fit to the NA flywheel.
iv just fitted an exeedy NA clutch (listed by exeedy as the '300zx single turbo' rated to 400bhp)...... so with that in mind.............
Single Turbo, so it sounds like a 300zx Z31 then.
that'l be fine en, if ur using your original flywheel and box in theory it should go straight in m8, i wouldent bother trying to put a TT flywheel on,,
how much was the clutch?? i need an uprated n/a clutch as ive got a n/a box to put in my TT auto.
