Water seeping into sectional garage
Anyone know of any products available from B and Q or wickes which will help stop water penetrating into a concrete sectional garage?. I went round the inside and outside of the garage with a cement (fillet) when I first built it. Unfortunately puddles form outside and seem to seep through. Anyone know of a product that I could possibly paint the cement fillet with to create a barrier?.
Heres an example
Concrete section
l l
l l
l l
/l l\
Cement Fillet / l l \
Thanks in advance.
Barry
would a brick sealer work, the stuff that you paint on and it creates a clear barrier.
Thanks Vijay, I was thinking of something similar , will have a browse around B and Q later.
Barry
just painted my roof with bitumin easy to use and not more leeks :thumbup1:
The only permanent solution would be to dig a french drain on the
side that is affected.
Got any pics?
vandex.... mix it like a really wet cement and paint it on...look it up on the web....
you might have to go to a builders merchant...
Thanks guys, picked up some brick sealer yesterday morning from B and Q, will give that a try, if not will go back and try the bitumen, as I looked at that first.
Sideshowbob, the problem is the concrete base is much bigger than my garage, as I had wanted to replace my old garage with a new one. Might do this some point in the future, so dont really want to dig into it.
Sideshowbob, found a picture.
Barry
