March 4, 201015 yr I need to remove a radiator so I can have the wall plastered, whats the best way of doing this as it will be off a while and I need the heating back on in the rest of the house. I have put a couple of photo's up with ref to the ends. Cheers Paul
March 4, 201015 yr its been a while since i done any plumbing but will give it a go do you have a combi boiler???
March 4, 201015 yr Author its been a while since i done any plumbing but will give it a go do you have a combi boiler??? Does a combi give constant hot water? Edited March 4, 201015 yr by Bigman
March 4, 201015 yr yes, but so does a water heater, how many pipes go into the bottom of your boiler, id there any other tanks or cylinders anywhere???
March 4, 201015 yr Author 1 small copper pipe into the bottom of it and 2 larger ones out the top, the bottom one is cold, both top ones hot. There is a cylinder upstairs mate.
Cheers Paul
