Xvid to DVD
Hi,
Can anyone tell me if there's an easy way to convert Xvid files to a DVD file that can be played on a normal DVD player?
Vijay
Cheers guys, will look into that when I get home tonight :)
I always use "convert x to dvd" have done for few years now. its easy to use and works well.
definately the best way to go:ninja:
yep convert x is awesome...so easy to use.....a 3 year old could use it....
Thanks again everyone, that worked a treat and so simple to use :bow:
  • 1 month later...
Another question on the subject, can you write a film to a rewritable DVD disc and play it in a normal DVD player and then when watched just put another film over it? The reason ask is cos I remember something with normal cd's that it had to be finalized (or something like that) in order to play on a normal cd player.
It'll work just fine, when you have finished with it and decide to write over it use your Convert X as you would normally, when it comes to the burn part it'll ask you if you want to erase what is already on the disc and overwrite it, simply click yes and it'll carry on. Simple!
No problems, as I do this all the time.
