I've just taken my steering column off for measurement, the column should be approx 746mm according to the manual and the lower shaft approx 315mm (RHD). I just want to confirm I'm measuring it correctly before I go and order any replacement parts.
I'm measuring from either end of the shaft to the centre of the connecting UJ pinion. Measuring this way I've found the lower shaft is correct for a LHD model (approx 280mm) and the column itself is about right at 745mm.
Perhaps the manual has LHD/RHD confused? Is anyone able to confirm the correct lower shaft length for a Jap spec RHD model please?
Hi Guys,
Thanks in advance.
RobH
