poly bush help
this is for my GTR but its not miles away from a zed.
can some one tell me out of 1,,2 and 3 which are uprated to adjustable arms and with new arms do they come with new bushes or not. i've looked and think its 1 and 2 that are adjustable, 3 will need 2 new bushes and the lower arm will need 2 new bushes am i right
If you are replacing No.1,2,3 with adjustable arms then they all have their own bushing/bearing at the subframe end, but retain the stock bushings in the Hub.
If your retaining Stock no.3 arm, then it has a bush at both ends, 1 in the arm, and 1 within the hub.
If you retain the stock lower arm, then it has 2 bushes to replace at the subframe end, and a replacement bushing/joint at teh hub end.
Most "kits' contain the bushings within the arms, which you are replacing with adjustable arms anyway, and rarely contain the hub bushings. Therefore its best to purchase seperately.
thanks i get what you mean. i am replacing for driftworks arms, but the lower/wishbone i will be powder coating my stock ones then putting poly bushes in. im not sure of the names thats why i numbered them, so 1 and 2 i have seen and are adjustable but 3 i cant seem to find that there is an adjustable one so if not i'll do the same as the lower arm. so as you said none of the hub bushes will not come with the arms
1. Rear toe arm / Hicas arm
2. Rear Upper arm
3. Rear Traction Arm
Can be called arm/rod depending on retailer.
2. Rear Upper arm
ah crap i didnt know 1. was hicas i wont be replacing that, one the bush i will but not the arm. thanks for the info
Edited by dipone
i am lowering my GTR by about 40mm and putting 18" wheels on do you recommened no. 3 "the traction arm" should be adjustable
