ECU Change
Hi guys need a bit of advice, Im considering changing my Mines ecu back to a standard one until I can get my car up to Jeff@Zedworld at the end of feb, at the moment my car is eating fuel like no bodies business. The car has following mods, FMIC, Decat Exhausts,K&N filter, Im no expert but i take it i can go back to a standard Ecu until i can get the car to Jeff for a once over and set up or will i just make things worse???
Cheers Craig
You can do as long as you drop the boost back down to stock if it has been increased. It shouldn't make a huge difference in terms of fuel consumption though, the problem is most likely elsewhere.
Cheers John, at the weekend im gonna go right over the car check connectors clean the filter, look for boost leaks etc change plugs etc see if i can do anything to help it last till i get it to zedworld.
Craig
