protoj · 2 hours ago 2 hr
Have you seen this What do you think.
http://www.telegraph.co.uk/news/uknews/road-and-rail-transport/6997339/Frail-elderly-drivers-should-be-banned-from-motorways.html
I think this bit says it all "We do not think this should be a blanket ban, but where there is medical evidence that a motorist could pose a risk to themselves and others, then this could be sensible compromise," said Neil Greig, the IAM's director of policy" but shouldnt that say if they pose a risk then they should lose there licence.
Wolveszx
