injector resistance
Hi all! Sussex Stu has very generously sent me an injector to test against my what i suspect failed one. I`ve just ohm tested the injector and i`m assuming it needs not to be given a current or owt, or am i wrong? Because the ohm read 74 which if all being well on how i`ve tested it would indicate that it`s screwed as well..or am i wrong?
From memory 10 to 14 ohms is a good reading.
Jeff TT
Cheers Jeff, that confirms that one then, will advise Stu to check the rest of his spares. :cry:
Sorry mate, came with a load of spares with the zed, is there anyway of checking the ohms on the others, to see if i should just bin em.
Stu
Stu
p.m sent mate
i got some if you get stuck.
dan.:biggrin:
Thanks Dan, will bear you in mind. I must say i`m feeling quite warm inside at all the generosity being offered by my fellow club members so a big thank you to you all! :bow:
