Got a Beeping Problem
When i put the key in the ing. turn it twice and the car beeps at me , then when i turn it again nothing happends (No Eng Start)
Any Ideas as i need to use the motor tomorow
Alarm/ immobiliser issue, or maybe a flat battery?
Jeff
how am i ment to sort the alarm out / immobiliser
disarm it first :punk:
joking aside, what alarm does it have? and does it seem to be operating normally? if there is a fault and the immobiliser is not switching off then you wont be able to start your car.
it doesnt have a alrm that im aware of nor a immobiliser , never turned anything off
in that case as Jeff says could be a flat battery. Probably got enough power for dash lights etc but not for starting. Have you used the car recently?
I have had the same thing for the past 2 days, flat battery.
I have mine on charge at the minute, but when i turned the key, i got a click and a beep beep from my alarm
havnt used it for about a week , its a daily ish runner
mine went flat after 3 days of sitting in the cold, battery is not that old, but it does say on the side, first charge required jan 09, so i guess its not as new as i thought lol
If you're getting a click it's probably a flat battery. They do seem to go flat quicker in the cold (as Groover has said)
ok i got a charger today and ill give it ago. the charger is a bit odd thou as it shows either that its full or empty and it hard to tell as the pic's are odd. but ill find out in 10 hours
