help with headlights
Hi guys;
I have HID lights now for 2 years, and only 1 is working, they are ok on full beam, i had this prob before but it sorted itself out,
Question ?
Can i put normal bulbs back in without removing the HID,s ? and what are the brightest ones available for a Jap spec and what fitment is it for a Jap spec ?
Cheerz
Chris
Hi guys;
Question ?
Cheerz
Chris
Hi Chris,
First of all, if only one side is working then you've either got a duff ballast or duff bulb. To check which it is just swap over the bulbs. If the same side fails to light up then it's the ballast, if the other side now fails then it's the bulb. I can supply both replacement bulbs and ballasts if need be.
Yes, you can change back to normal bulbs without removing the HIDs. All you need to do is remove the HID bulbs, by doing so you'll have disconnected the spade connectors from the grey connector block. Then install H3C bulbs and pop the grey connector block onto the back of the new bulbs - job done!
I've got H3C bulbs in stock (generally speaking otherwise it'll be a day before I've got more). The brightest you can get are our 55W Extreme White bulbs (rated at 4500K). £11.00 for a pair plus £4.20 via Recoreded Delivery.
Let me know if I can be of any further assistance.
Regards,
