- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi guys, I'm from Australia, but hoping you can help..:) Ok this is weird so please bare with me while I explain.. The zed (1990 NA, 5 Speed) has developed a very annoying electrical problem, this is what it does: Drive the zed around and all is fine. All of a sudden I will start to hear a whine coming through the car, that rises or decreases based on the revs of the engine. This whine will come and go but will always be present for the rest of the drive. Then, when I finally come to a stop and switch the car off, I lose all power. As if someone has taken the battery out of the car. No alarm ( I cant arm or disarm the car, and no flashing LED), no interior lighting, no ignition, no head lights. The power is just completely gone, like I said, as if someone has walked away with the battery. And then I wait. All of a sudden, anywhere from 1 minute on wards all of a sudden all the power comes back (why this delay in time?? Does something need to cool down?). My alarm starts working, the LEDs flash, the interior light comes on and I can start the car. When the power comes back, the clock has reset itself and the climate control has gone back to 25 degree's celcius, the default position as what happens when you disconnect and then reconnect the battery. This weird electrical issue only happens on long drives (say 20min +). A short trip down the road and back, and everything is fine.
Ok so, anyone have any ideas on where I can start trouble shooting??
This is what I have done so far:
1) Checked all stereo wiring. Because the first sign of something being wrong is the alternator whine coming through the stereo, I have checked and double checked all the stereo wiring. Everything is fine. Also, the stereo wiring has not been touched for ages so it is odd that something would be wrong now. And the stereo would not be responsible for the total power black out.
2) While driving, the electrical system is fine. The volts are between 13.5 - 14 (I have a volt meter installed) and the battery holds charge, and the car starts at the turn of the key (when the funny power blackout thing isn't happening).
3) Fuses. Don't know where to start here. In my mind a fuse would either be blown or be ok. Whereas this seems to be intermittent, as if something needs to cool down and then all power comes back. Any fuses I should check?
4) Alternator. The alternator is new, bought from Coz (ConceptZ, U.S) earlier on in the year. I have no reason to think that it is at fault. However, since installing it, I do remember my car having some odd electrical problems in the past on 2 separate occasions. I was able to start the car on those two occasions, but did notice that the clock and climate control had reset itself. At the time I thought what the hell?, but I brushed it off and thought nothing of it. Now, since its been warm here in Aus, it does it every time I drive the car (long drive).
Any help would be much appreciated so I can find this electrical gremlin hiding in my car.
Many thanks
