Front suspension upper links
Hi everyone, hope someone can help, when i brake at low speed (5mph) it seems like my struts move slightly, a mechanic said that the problem is movement in the upper suspension links, can any one please tell me where i can get some second hand ones or should i buy new ones (if so any ideas where from).
thanks bobbyzx.
I have a pair of second-hand ones from my car available for £20 + postage, if of interest to you, mate? Other than that, new items should be available from MJP and possibly DTA on here or possibly one of the suppliers from the States - http://www.Z1motorsports.com or http://www.conceptzperformance.com (I don't believe they're listed, but may be available if you contact them). After market adjustable ones will also be available from various places including DTA, Z1 and conceptz already mentioned.
Pretty sure Uno had this problem, hopefully he'll post if he did
You can replace all the bushes in the upper links. 4 each side - can cost £160ish for parts.
You could also have replaced tension link bushes and if the bolt and nut through the bush is not really tight the link moves under braking forward and then reverse making a clunk sound.
Thanks everybody for your responses, my car will be going on a ramp some point this week, then i will know the cause.
Fastorquer i will get back to you on wether i need the upper links.
Once again thanks for your responses.
Bobby
