FIXING MY CAR'S SPONGY BRAKE PEDAL ISSUES ONCE AND FOR ALL
With both of my front and rear brake caliper restoration projects now on hold for the time being, it's time to shift my focus towards getting my Z back on the road. However, before I can do that, I first need to finish diagnosing and resolving the spongy brake pedal issue that has plagued my car for the better part of the last 12 months.
The problem originally surfaced during what should have been a relatively straightforward brake pad replacement and brake fluid system bleed. Unfortunately, following the work, my car's brake pedal developed an unusually soft, spongy feel with excessive pedal travel. The brakes were barely capable of bringing the car to a complete stop, making it unsafe to drive and forcing me to take the car off the road until I could figure out what was causing the problem.
After struggling to identify the cause of the spongy brake pedal issue myself, I decided to seek assistance from a local mechanic to see if he could help diagnose the problem. Unfortunately, even with his expertise and specialised equipment, we were still unable to pinpoint the cause, and my car's brake pedal continued to feel spongy no matter what we tried.
Since December 2024, I've spent countless hours researching the various causes and symptoms associated with a spongy brake pedal. I've also spent months pulling apart and inspecting various braking components in an attempt to get to the bottom of the problem.
Well, after all this time, the mystery has finally been solved!
I can now reveal exactly what was causing my car's spongy brake pedal issue, and the answer was something I had overlooked right from the very beginning. In fact, I can explain the entire problem with just one simple photo.
https://i.postimg.cc/mrFVrCsn/0-Brake-Caliper-Issue-Discovered-Feb-25.jpg
Yes, you guessed it! My front brake calipers were installed upside down!
I have to admit, I feel like a complete idiot for overlooking something so obvious, especially considering how much time and effort I've spent trying to diagnose this problem.
So, how exactly does installing a brake caliper upside down cause a spongy brake pedal?
The problem comes down to the location of the brake fluid inlet and, more importantly, the position of the caliper's internal bleed point. When a brake caliper is installed in the wrong orientation, the bleed point can end up below the highest point of the internal hydraulic passages. This creates an air pocket that cannot be effectively removed through the normal bleeding process.
In other words, no matter how many times you attempt to bleed the braking system, trapped air can remain inside the caliper because it has nowhere to escape.
For the bleeding process to work correctly, the caliper needs to be installed in its intended orientation, with the bleed nipple positioned at the highest point of the hydraulic cavity. This allows trapped air to escape as brake fluid is pushed through the system.
As it turns out, this was exactly what had been happening with my car.
What's even more interesting is that I actually discovered the problem completely by accident!
One day last month, I randomly decided to look through some old archived photographs from my 2Kspec conversion build project. While browsing through the photos, I came across an image taken shortly after I had installed a freshly painted set of front brake calipers and BDE rotors onto the car.
After taking a closer look at the photo, I noticed something that immediately caught my attention.
The brake fluid hose connection on the back of the original front brake caliper was positioned at the top of the caliper.
https://i.postimg.cc/g06408pd/0-Photo-of-brake-fluid-hose-discovery.jpg
It was one of those lightbulb moments where everything suddenly started to make sense!
I immediately rushed out to the garage to inspect the front brakes currently fitted to my car and compare the orientation of my TT front brake calipers against the ones shown in the old photograph.
Sure enough, I discovered that the brake hose connections on both of my currently installed front brake calipers were positioned at the bottom of the calipers rather than at the top.
This was the breakthrough I'd been looking for!
However, there was still one question I needed to answer.
My Dad was the person who installed these TT front brake calipers back in February, so how had he managed to install them in the wrong orientation?
Unless, of course, the original non-turbo front brake calipers had already been installed upside down to begin with, and he had simply transferred the replacement TT calipers across in exactly the same orientation without realising anything was wrong.
That's when I finally pieced together what had happened over the course of the previous seven years.
And as it turns out, this entire mess was actually my own fault!
You see, the original mistake happened all the way back in 2017.
At the time, my car had been experiencing some pretty severe brake shuddering symptoms for several months. After determining that my existing BDE TT front brake rotors were badly worn and warped, I decided to temporarily remove them and install an old set of non-turbo front brake calipers and rotors that I had lying around.
The plan was simply to get the car back on the road until I could afford to purchase another set of replacement TT front brake rotors.
Unfortunately, during that brake job, I made several rookie mistakes. One of those mistakes was allowing the brake master cylinder reservoir to run completely dry of brake fluid. Looking back now, I also realise that I must have installed the replacement non-turbo front brake calipers upside down without even knowing it.
After putting everything back together, I attempted to drive the car home, only to discover that the brake pedal had developed that same horrible spongy sensation. The brakes were barely capable of bringing the car to a complete stop, and I immediately realised that something was seriously wrong.
Fortunately, I managed to limp the car back to my Dad's place, where I had to wait until he returned home the following day so that we could try to figure out what had gone wrong.
What followed was an entire day spent attempting to bleed the braking system, but despite our best efforts, we simply couldn't get the brake pedal feeling right.
Eventually, I had to borrow my Dad's car for an entire week before he finally managed to get my car's brakes working properly again.
At the time, neither of us realised that the front brake calipers had been installed upside down. We had simply assumed that the problem was caused by air trapped somewhere within the braking system and never thought to question the orientation of the calipers themselves.
So, when you think about it, I've potentially been driving around with incorrectly installed front brake calipers ever since 2017!
It's a pretty unsettling realisation, to say the least. It also explains why I was never able to successfully bleed the braking system after replacing the brake pads back in December 2024. The underlying problem had been there all along, and no amount of conventional bleeding was going to completely resolve it while the calipers remained incorrectly installed.
What makes matters even more frustrating is that, during my research into spongy brake pedal symptoms, I came across multiple videos explaining how incorrectly installed brake calipers can cause exactly this type of problem.
I had actually been presented with the answer several times throughout my research, but I was so convinced that I couldn't possibly have made such a basic installation mistake that I simply dismissed the possibility.
Looking back, I really wish I had paid closer attention to that advice, as I could potentially have figured everything out months ago!
With the mystery finally solved, it's time to put things right and hopefully get my Z back on the road once again.
The plan is relatively straightforward. I'll remove both front brake calipers from the car, reinstall them in their correct orientation, and then perform a complete bleed of the hydraulic braking system.
If everything goes according to plan, I should finally have a firm brake pedal and a fully functional braking system once again.
Let's get started!
Front RH Brake Caliper Removal Process
https://i.postimg.cc/3N9FqZXn/FSM-Front-Brake-Caliper-Removal-Process-Illustration.jpg
I'll begin by removing the front brake caliper currently installed on the right-hand side of the car.
https://i.postimg.cc/fLnCSyW4/2-Brake-Pad-Removal-Process-1-RH-(Start).jpg
The first step was to remove all the brake pad retaining hardware before removing the two brake pads currently installed inside the caliper.
https://i.postimg.cc/SsFdYRQX/2-Brake-Pad-Removal-Process-2-RH-(with-Tool).jpg
https://i.postimg.cc/fLcKcskm/2-Brake-Pad-Removal-Process-4-RH-(Pads-Removed).jpg
With the brake pads and retaining hardware removed, I could now move on to disconnecting the brake fluid hose located at the rear of the caliper.
https://i.postimg.cc/ZR8c8m0H/3-Brake-Hose-Disconnect-1-RH-(Start).jpg
To avoid damaging the hexagonal brake line fitting during removal, I used a dedicated 10mm flare nut spanner. This type of spanner provides better contact with the fitting than a conventional open-ended spanner.
https://i.postimg.cc/tT353b7r/3-Brake-Hose-Disconnect-2-RH-(Tool).jpg
Also after disconnecting the brake hose, I fitted a specialised brake line clamp tool to minimise brake fluid leakage from the disconnected hose line.
The final step was to remove the two mounting bolts securing the brake caliper to the wheel hub assembly.
https://i.postimg.cc/13SNFFwb/4-Brake-Caliper-Removal-Process-1-RH-(Start).jpg
With both mounting bolts removed, the front right-hand brake caliper could finally be lifted away from the wheel hub assembly.
https://i.postimg.cc/50B3BJjD/4-Brake-Caliper-Removal-Process-2-RH-(Caliper-Removed).jpg
Front LH Brake Caliper Removal Process
With the right-hand side caliper removed, I repeated the same procedure on the opposite side of the car to remove the front left-hand brake caliper.
https://i.postimg.cc/5yfmprFD/5-Brake-Pad-Removal-Process-2-LH-(By-Hand).jpg
https://i.postimg.cc/htn7mmTH/6-Brake-Caliper-Removal-Process-2-LH-(Caliper-Removed).jpg
With both front brake calipers now removed from the car, I could finally begin reinstalling them in their correct orientations.
Front LH Brake Caliper Installation Process
https://i.postimg.cc/cCTBzcRm/FSM-Front-Brake-Caliper-Installation-Process-Illustration.jpg[/img]
Since I'm already working on the left-hand side of the car, I'll start by reinstalling the front LH brake caliper onto the left-hand wheel hub assembly.
After positioning the caliper into place, I prepared the mounting bolts for installation.
https://i.postimg.cc/kG7ywHb4/7-Brake-Caliper-Installation-Process-1-LH-(Start).jpg
https://i.postimg.cc/j2v41hHf/7-Loctite-Applied-to-Caliper-Mounting-Bolts-1(Start).jpg
https://i.postimg.cc/J7QxtR9S/8-Loctite-Applied-to-Caliper-Mounting-Bolts-2(During).jpg
I applied medium-strength (blue) Loctite to the caliper mounting bolt threads to help prevent them from loosening over time. The mounting bolts were then installed and tightened according to the manufacturer's specified torque requirements.
With the caliper securely mounted in its correct orientation, I could move on to reinstalling the two front brake pads and reconnecting the brake fluid hose to the rear of the caliper.
https://i.postimg.cc/WzSwy7G2/7-Brake-Caliper-Now-Installed-Fully-LH-(End).jpg
https://i.postimg.cc/J0K5FQN0/7-Brake-Hose-Installation-Process-2-LH.jpg
With everything back together, the front left-hand brake caliper was now correctly installed!
Front RH Brake Caliper Installation Process
With the left-hand side completed, I repeated the same installation procedure on the right-hand side of the car.
https://i.postimg.cc/D05PNcrL/8-Brake-Caliper-Installation-Process-1-RH-(Start).jpg
https://i.postimg.cc/D05PNcrd/8-Brake-Caliper-Now-Installed-Fully-RH-(End).jpg
https://i.postimg.cc/y6TjW7w5/8-Brake-Hose-Installation-Process-2-RH.jpg
And with that, both front brake calipers are finally installed in their correct orientations!
After months of troubleshooting, researching and pulling apart various braking components, I've finally managed to identify what was causing my car's persistent spongy brake pedal issue.
There is just one last thing left to do before I can find out whether all this work has actually paid off.
It's time to perform a complete bleed of the hydraulic braking system and see if I can finally get that firm, consistent brake pedal feeling back again!
To be continued...
DJ_Party_Favor ·
Who's got one and how much for it?
I need one ASAP to cover my Bass box in the rear, a whole Rear Carpet will cover it nicely!
Matty.
Bounce...Bounce...Bounce...Bounce...Bounce...Bounce...Bounce... (sorry no sound!) LOL
