Fitting 555 injectors
Thinking about fitting 555 injectors but do i have, my ecu remapped and will these work without blowing standard tubs and inner's of my engine!!!
With a remap, injectors and air filter you will get a decent gain but I'm sure someone will be along soon to confirm
running 555's will able you to run the oem turbos to full boost but old turbos and engine + high boost = bang ;)
Is it not safe with a small boost increase then rather than a full on increase?
you will need a remap but will gain some decent power and internals and tubs will be fine as long as they are in good working order with no problems.
what i mean is with oem injectors you will run say 14 or 15 psi and the bottom end seems to handle that ok for a good while but you stick 555's in and you are going to want to run even higher boost so all its going to do is put even more strain on an already ageing bottom end ;) i just cant see the point of going to all that trouble for 2 or 3 extra psi :)
Mike
Mike
Thanks for clearing that up, I've read about so many people running 555's on standard engines with no problems got confused as to why it could be a problem. Glad I have a fresh rebuild then with 740's !!
