crossed poles
my mate tried jump starting his car using his moms renault megane however the positve jumper cable fell and touched the neg... now the car will not start.... any ideas as i think he is going to be killed if he cannot sort it ?? :D lol
  • Replies 30
  • Views 1.1k
no nothing.. its as if its completly dead, hazards etc work but thats it... lol we are in deep shit :)
also we voltmeter tested the battery to make sure we didnt kill it but battery is perfect , at the min we are looking for fuses etc
hmm are there main fuses off the batt that could have blown? I have 4 mains fuses on the batt before the fusebox on my escort
there are a couple of little orange things but cannot tell f they have blow or not.. as the look like normal still
you can use that to see if the fuses are blown
Check in the glove box, there should be a fuse box with main fuse
will have a look now
ok checked all fuses but they seem fine, there one relay inside the glove box fuse panel which is also fine ??
Check on or near the battery pos lead (near battery) . is there a cover that could house fuses. I think they have a main fuse located around there
you have prob burnt the wire out back to the ignition, this happened once in my fiesta after an "expert" fitted my radio
yourll have prob burnt through a wire if left long enough and yes sorry to say but there all rapped up the quikest and cheapest way is a good rep auto electrcian one that a local garage would relie on dont take to dealer there charging you 45 plus anhour whilst srathing there heads.hope you find the fuse.start at the begining and check one buy one with meter.
ok guys thanks for all your help... there was a wierd shaped fuse on the battery 32 amp ..... and we decided to wrap some speaker wire arouns it to re connect the ends and viola it worked the lights came on and we decided to jump around the garden giving high fives......we didnt however realise that his mum was at the front door and asked ... why are you two so happy,,,, so we came out with the first thing that came into my head which was .....' your tyre pressures are all fine' she did walk off so it did the trick... we then attached all the plastic covers etc and locked up..........what a day!
Cheers guys!
:D
