Nzr vosa mot help
evening all. right my ikle clio has failed mot on rear brake application uneven (3.7.a.5c)
now the mot tester was a little vague as to what the problem is and i can't find any reference to what is uneven. this evening i have taken off the rear ns hub and the shoes look like they have been recently replaced and the handbrake and wheel cylinder are all working. havent taken off the drivers side yet but at a guess would say that the shoes would have been done too
can anybody shed any light on the actual fault from the code given
thanks
gaz
well i think i have the answers i need for the brakes. now lets hope i fixed the other fault (emissions ) LOL. a change of cat and lambda sensor should work (x fingers)
many thanks
gaz
well dont know the code but i believe only the front breaks have to be even. as long as the rears both come above the standard limit they should pass????
__________________
nearly right!.
Cant fail rears on imbalance, but you can for rate of increase not being about the same level!
