mouse pad stop working
the left click action on my mouse pad has stopped working, i can still left click using the button and the mouspad still moves the cursor about but it doesnt let me left click when tapping on the mouse pad, the cursor stopped working earlier (it froze) for a few minutes and when it started to work again i coldnt left click
any idea's as to why this has happened
  • Replies 27
  • Views 1.1k
do you mean the mouse mate? or are you tapping like a 'tard on your mat? lol
Try unplugging the mouse and sticking it in again.
ps. cracking sig :bow:
its on my laptop, i have touch sensetive mousepad built in, when i click on the pad instead of using the buttons its not working now
Hmmmm could have sworn I'd replied to this earlier!
:smw: Ok perhaps it was a bit off topic but was meant in jest, and seeing as you are probably the most consistent at being off topic, I think it was a bit rich deleting it. :nono:
i wasnt getting at anyone, i want to get it sorted, i didnt just delete you, i keep peoples threads on topic
i am not the most consistent at being off topic, i always get at other people for doing that
The left mouse key aint working but I see the humour delete button is. are all threads that go off topic going to be moderated now :confused:
ffs people wind ya necks in, i posted a prob that needed sorting, since when did i come onto your posts changing the subject to something totally irrelevent, i changed the sig as it was a bit of banter and it wasnt really appropriate for the forum
keep on topic please, i have plenty of other threads where you's can take the piss to your hearts content
i am but when i quietly delete something to keep it on topic then get a load of snide digs i dont like it, i have banter all the time, there is no need to go getting offencive about it
have you got a USB or PS/2 mouse you could try? I've never got on with the touch pads cos they're far too temperamental for me.
no mate, ive only ever used the touchpad, had this lappy for some time now with no probs, it never gradually slowed it just stopped, have scanned hundreds of google threads but to no avail, i can still navigate the cursor just not use the left click or double click facility, quite annoying once you have been used to it lol
Sounds like it's on it's way out mate. Get yourself a usb mouse from ebay. Should only cost you a couple of quid. Windows should automatically detect it.
There's sometimes a button on your keyboard that disables the touch pad, if you have the manual have a look, or see if there is something obvious on the keyboard
cheer mate, i may have pressed a few buttons when it froze, seems strange that i can still use the touchpad to move the cursor but not to double click
Try doing a 'system restore' to when you know it worked ok. Is the let click a button or by tapping the mousepad? If it's a button, the switch under it may have failed or have a dry joint on the circuit board.
If it's virtual (tapping of the pad) that doesn't now work, then there will be adjustments in the properties of the mouse in the control panel.
The system restore will put it right if it's been disabled.
its the tapping of the pad that has suddenly stopped, how do i do a sytem restore
cheers
sorted it, right click on the synaptics pointing device icon, then press tap click
cheers people, now you's can go off topic and take the piss as much as you's like now
go nuts
you should buy a usb mouse though....cheap as chips......i hate them touchy sensitve pads.....
not now its not, its fixed wuwhooooo
Thank fook for that Alonzo :D Your getting more like Spunky Thigh every day ;)
