maf question
i noticed since swopping mafs that the two i had both had 4 pins for the connection my maf connection has 5 pins :confused: and i found a picture of a maf with 5 pins as you can see from the pics can anyone shed some light on this PLEASE?
dan.:D
I've noticed this too. A maf off my '89 jdm has five pins and a '93 Uk has 4. Luckily the harness has 5 pins and I've run both in my 93 UK without any problems.
well asked around and one Z 1990 had same connection with five pins and another Z a 1993-4 with a new loom had 4 pins but both had mafs with 4 pins! whats the extra pin A for?
dan.:confused:
Could this be an Import / UK Maf difference thing. I have only had import Zeds and all have had 5 pins.
good point! mines is an import so is west and think john's is import but with a new loom anyone with a UK can check to see how many pins on maf loom? i am thinking that if the maf connector has 5 pins then 5 pins should be used.
dan.:)
well turns out the majority of peeps running around all have 4 pin maffs and 5 pin maf connections, aparantly pin A is not used, i have a 5 pin maf coming from the good old USA which i will be using.
dan.:cool:
postman delivered this today!:hyper: 5 pin maf/afm its got 5 pins for a reason!:)
dan.:cool:
Be Interesting to see what difference it makes Dan! If any good I want 5 pin one!
there like hens teeth to find! see you wednesday for a review!;)
dan.:cool:
