protoj ·
there is a pic in my rides section. http://www.300zx.co.uk/rides/jizz/jizz side.jpg
lowered,
toad cat 1 alarm
resprayed black non metalic two months ago £1500
new antera 309s 18" 265 35 18 rear 245 40 18 front all new bridgestones S02 cost £2000
118kilometers approx 75000miles.
must be seen this one is mint.
cambelt service done 4000miles ago.
paul bailey rear lights quad.
z center tailgate skin.
tel: 07786805698 or 01341241573 jason.
BARMOUTH NORTH WALES.
SERIOUS OFFERS ONLY must be seen.
