is this big brake kit worth the money?
Hi
I need to upgrade my brakes and would like to know if this set is any good! This set is a big brake kit from Revolution Brake LLC.
Price is $800 dollars + shipping.
The set includes:
ROTORS, 323mm diameter, 30mm thick (about 12 3/4" x .1.18") curved vane directional, cross drilled. The curved vanes are designed to pump air through the rotors as they rotate for superior cooling in high performance driving conditions. The huge thermal mass and cooling efficiency of these rotors virtually eliminates brake fade. These are 43 mm larger in diameter than the little stock rotors!!!
CALIPERS, Wilwood forged Superlite four piston fixed mount. These calipers are extremely rugged and light to help reduce unsprung weight. The forging process allows for a very strong rigid design without the use of excess material, they are super light (4.5 lbs compared to stock caliper around 9 lbs each). For more information look on Wilwood's site, http://www.wilwood.com/Products/001-Calipers Don't be put off by their excessive use of "racing", it's all about liability. These calipers can be found in Wilwood street kits also, though they are equally at home on the track.
PADS, Wilwood BP10 'Smart Pads' low noise, low dust compound designed for high performance street use. For more information on this compound look here: http://brake pads.wilwood.com/01-selection. This is the best street compound on the market!!
MOUNTING HARDWARE: Adapters are heavy duty steel, powder coated for corrosion resistance and appearance. All hardware is grade 8 and 10.9 or better including flat washers.
FLEX HOSES: Stainless steel braided Teflon hoses are included with fittings specific to the Nissan chassis.
No posts to show
