couple of questions?
Ok........;UK version TT here.
filled up my screenwash today and its not working, cant even hear the motor. this is probably one for stella(has it been removed?)
Rear lights on the centre panel of the car....reverse lights are working...what are the other 2 lights? These are not coming on no matter what button i press.lol.
Front left headlight is fine on dip beam then when i put to normal lights for driving the light still stays as a dip beam. And this oviously also has a knock on effect for my full beam? Is it to bulbs to the dip beam? possible problem?
Edited by CraigTT
All 4 rear lights on the centre panel are for the reversing lights, but what happens with a lot of import cars is that 2 of them on one side are used as Fog lights.
Yours is a UK TT so should have fog lights fitted in the rear bumper, unless it has been changed.
In fact I know it looks like there are 4 lights in the centre panel, but there are actually only 2 bulbs, I bet one of your reversing bulbs is out that's all.
As for the fronts, there are 4 bulbs, 2 for high beam, 2 for dipped. I'm not sure what happens with the UK spec car. Is it not just one of the main beam bulbs that's out?
I don't know if the dipped beam is supposed to stay on with high beam. What happens with the front right? Check the bulbs and failing that fuses. I believe strange things can happen with the lights is a fuse is out...might also explain why the washer motor is not working if it shares a fuse.
1. Dead motor, or its come disconnected.
2. Although there are 4 lenses, there is only actually 2 bulbs. 1 for the left, 1 for the right, that should light up both lenses on that side. If only 1 side it working then either a bulb has gone or its been connected up as the Rear fog lights instead.
3. Sounds like the Dipped beam is earthing out.
the washers used to work ok,but as ive found with lowering the car, things can come a little loose with the extra vibration, maybe just come loose
anybody direct me in the correct direction for the fuse location in the box for lights and washer and position of washer motor.
The rear centre panel is fine......i have 2 reverse lights and the fog light has been disconnected until MOT time.
