Help Needed.
Hi ,new to the ZX what have i done ? only owned 1 and a half weeks only just had MOT 3 weeks thought this would be good when i bought it ago just noticed rear light are not working and it appears omly the head lights work. any ides please cant find fuses for rear lights thanks kev
Have started this in your own thread mate and in the correct section :)
I'm guessing only your full beam is working and if so you need to replace a fuse. Next to the accelerator pedal there is a plastic cover, remove it and it will expose a load of fuses. It is one of the top ones, a 10amp.
Job Done.
HTH :)
Welcome, your rear light might be out, if it is, you will see a red light lit up on the dash which looks like a circle with 3 lines coming off of it, if this is lit up then one of your bulbs is out!
Is that not the Cat overheat light you're talking about? :confused:
Nah, maybe its just a uk thing?? If one of my bulbs is out a light comes on telling me, it measures it by the amount of current going to the lights
I agree with zx-eyes it does sound like the cat overheat light your describing! On my jap spec the light with your description is the cat overheat light and the bulb warning light is a red light showing 'LIGHT' :)
Oh how weird! Mine is how i described it, im sure it is
