Me again.
So I have two questions:
RobHowl ·
Hi,
As some of you know, I've damaged my rear 300zx Black Plastic Panel (that sits between the 2 rear lights).
Has anyone got one in newish condition to sell ? If so, how much (inc P&P) ?
Thanks.
A.
