Pics up !!
Hi guys, a couple of you wanted to see some pics of Marks Hi-Fi install. Well thanks to Craig there is now a link over there on the left called "Bobs place" As i do bits and pieces on Z`s i will post some pics and tips incase you want to have a go yourselves. I will shortly be putting some pics up of Andy`s TV and SatNav install, Rod`s alarm fit and hopefully a step by stap guide to fitting the AVC-r which i will be doing on Daves car this Sunday.
If you need any help or advice regarding car alarms or hi-fi drop me a line, advice is free and extra discount given to all Z owners.
Later
Bob
hi i want to fo#it a set of speakers in the rear locations without modifying it , can you suggest anything i have a jbl split system in the from with a kenwood cd player, im not afetr big sound just something standard to fill the rear, ps what size are the standard rear,
Bob, that is a kickin install!! How can I get the details to do it on mine. I've been meaning to do it for some time. I have got my three alpine amps buried under the original floor, sort of all hickledy pickledy. I've also got a twin 8" bazooka base tube. I would like to get the whole install looking hot.
Regards
Grant
Rear speakers, when i did Marks i phoned around a few suppliers looking for the best 6/4 speakers on the market. A number of them came back reccomending Kicker, so i got a set to try. Well after putting them in i can honestly say they kick! For a small speaker we had to turn the gain`s on the amp down as they were bouncing. The only mod reqd to fit then was the drilling of 4 holes as they don`t quite line up, also if you get a set use the thicker spacer, you won`t be disapointed!!
Grant, the best thing to do is give me a call to start with then i can get an idea of what you`re after, 01244 380915, we`ll take it from there.
Bob
This is mainly aimed at Bob (THE GOD so you all say). With the Bose systems with a centre speaker in the dash, is there any point in keeping it?
Also do you know what the best speakers would be to replace the front door speakers are?
Sorry but more, Do they have any amp's hidden amoungst the car or is it all run from the head-unit?
By the way I also agree Kicker 6*4's are the best I've seen as well, fitted a few sets to Golf MkII's during descrete installations.
Paul (Chichester Sussex)
5 1/4`s go in the front ok but you will probably get a set of 6`s in. Take the Bose system out and re-wire it all! There is an amp built in and you will find it under the plastic panel in the boot, near the ABS system
Bob (not quite a God)!
I have a pair of Infinit Kapa 3 ways 6.5inch in the front.
