noise
Hi all my Z makes a horrible noise at about 120-130mph when the window is down, its very loud, like the wind is getting stuck somewhere, i know it will be noisy with the window down at high speeds, but this was stupid, & it only started between them speeds, can you buy wind deflectors for the windows, could it be the seals around the T bar roof as they do look slighty worse for wear. thanks all.
well.......... that speed is interesting in the first place..
sounds like you often reach them speeds ;)
anyway back to the topic.... when you next take it for a drive, dont have windows open at that speed . hehehe
i wouldnt anyway because you will only slow yourself down with the wind rushing in and hitting the area in the boot.. it's not your blind flapping about is it?
Edited by damien
forgot to add drive
number 1, i never do them speeds in the streets or built up area's, when i am doing them speeds i am in the car on my own helmet on, and on a track, but the time in mention i was just accellarating hard, looked down when i heard the noise.
don;t worry dude i am just playing with you....
i do it all the time (when the car ACTUALLY runs right)
if you do have your window down then where is the noise coming from?
Only reason i ask is because when i had a noise it as my blind flapping
no i look down at the speedo, thought i was breaking up lol, no now you mention it, it proberly was the blind as its quite loose, yeah the blind, its not the wheel, its the blind lmao, i'll keep the window as door panels ect might start flying out, my car sounds like eveything on the inside is loose when driving, anyone cured the prob, & managed to reverse the aging process.
well first thing you can do is unhook the blind from the boot door and see if it does it again. i am getting anew one made so for now i leave it reeled in
