is there a diagram or thread on how to put in new but standard fuel pump, did a search but couldnt find any, thanks guys, having a stressful day, get 1 thing sorted abd something else goes:headvswal
  • 1 year later...
Bloody pain when you have big hands good luck boyoh lol :whistling:
Overall quite straightforward matey just make sure all the seals are airtight once you've finished :smartass:
ย
Goodluck :winkiss:
thnx very much for that guys. no fuel going to engine. a friend of mine is working on my car, he suspects the fuel pump. checked few things. he actually gona remove the fuel pump now. now to get a replacement.
Have you checked the fuel pump fuse and relay?
ย
yes. we checked, thats the one under the bonnet by the drivers side, close to the windscreen right?
Yep, but also in the drivers footwell is a relay which takes a signal from the ECU before completing the fuel pump circuit.
ย
Also theres summit (can't remember what lol) in the rear quarter panel passenger side i think which deals with the fuel pump and it's gubbins!
ย
I've not messed with a pump before, but assume you can put a direct feed to it to see if it works? this will then at least tell up if it's pump failure or a wiring/relay/fuse etc issue
ย
Smithy
