whats the difference in balance bars between man n auto
Is there any difference??
[sIGPIC][/sIGPIC]
So when a auto to man conversion gets done i suppose that gets changed. Just wondering because my boost gauge on the dash has started not to work properly. My aftermarket works and says im boosting ok. So must be the connection.
[sIGPIC][/sIGPIC]
It would of been changed, or they may possibly have used a T-piece off the Brake booster pipe.
Probably the little pipe has come loose from the bottom of the Boost sensor (near the small fuse box in engine bay)...or they refittted the aftermarket boost sensor up to the balance bar in place of the original boost gauge pipe.
Yes the balancer bar was changed, most likely as Legrath has mentioned the small pipe has become dislodged on the boost sensor or the sensor itself has an issue, have a check and if you need a new sensor let me know and will pop one in the post for ya.
Jeff TT
Cheers Jeff!!!, Helpful as ever!!!:bow:
[sIGPIC][/sIGPIC]
