Fitting dump valves
Can anybody help me, got new 2 Blow off valves, but have not got a clue how to fit them anybody help?
Are these easy to fit or do i get someone to fit them?
Yes Pete they are! Are you going to give me bad news!
Edited by cheshire300zx
press return in error
First you got ripped off sorry, they sell on ebay for £50 for two elseware.
They are turboXs replicas, i have some and they are really loud.
They fit in the standard recirc location and are really easy to fit mate
If you dont want to fit them yourself and you dont trust garages, i live not to far away and could fit them for you.
Remove the centre panal and air filter assembly, remove the aux fan, remove both original dump valves which are held in with two 12mm bolts.
Connect the dump valves to the engine side of the hose with a jubilee clip (bin the originals)
plug up the other pipe with the supplied plug.
Connect the hose supplied to the top of the dump valve with a cable tie and use a hose joiner to connect it to the original vacuum line.
Refit fan and air filter assembly and job done
the turboXs valves also have adjustment washers to insert if you have a bad idle after installing them, quite handy really as some cars dont take well to dump valves.
Mine didnt use any tho :)
30mins, maybe 1 hour max, but make sure you get some jubilee clips a little bigger than the end of the dump valve before you start, you will need 4.
Are these any good then? as i want to replace mine as there very quite... almost sound like re-circs?
those are the same as the ones above,
If you buy these ones though, they are half the price and you only need a bit of hose and a few blanking plugs
http://cgi.ebay.co.uk/UNIVERSAL-BLOW-OFF-VALVE-SINGLE-TRUMPET-DUMP-VALVE-NEW_W0QQitemZ310113650871QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item310113650871&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Cheers Pete, may have to treat myself on payday!
