protoj · Tuesday at 18:48 4 days
Hi all,
The warning light on dashboard is showing all doors open,when in fact they are all closed, plus the overhead map reading light and the interior boot light is not working.
Would it be a fuse or fuses?
Its a Jap spec so problem with language.
Does anyone know what fuse or fuses it could be?
Cheerz
Chris:headvswal:headvswal
