French door help
Morning,
The lock on my back door is playing up, the spring in the handle has gone. Not sure what the type of lock is but it's in a UPVC door, takes a euro cylinder and the mechanism runs completely up the edge of the door. It jas 4 hooks that come out when the handle is raised as well as a straight bar in the middle which shoots out (as well as the latch).
My question is can I just change the actual lock part or do I need to get the whole mechanism from the top to the bottom of the door?
Vijay
If it's just a case of the spring in the handle, then a new pair of handles
will do the job. Does the lock work ok apart from the handle?
Some handles have a plastic spring clip inside the handle, could try
turning this round.
Got any pics ?
No the handle doesn't have any springs, they just turn 360. Pretty certain the spring part is in the lock itself :(
Ah, i see.
A good locksmith may be able to strip the lock and replace the part.
Failing that, then yeah you're gonna need a complete lock, it's called
an 'espagnolette' locking system, a specialist job i'm afraid, not the
type of lock you can get in B&Q.
Cheers bud. At least I know what I'm looking for now :)
