Mines ECU 555 injectors
Anybody ever seen a JDM ECU that is not one for a stock car?
I want ECU for 555's and hybrid turbos, Stillen intercoolers, induction kit and exhaust
Can you do one for me ;).
On a serious note I'm sending you the bin file shortly. Haven;t had a chance to get it off the laptop yet.
I can do you an ECU for that spec no problem. Only JDM ones I've seen are JUN.
Will probably need it John but the only donor ECU's I have are all JDM chipped ones a la mines etc. . They all have that goo all over the chip.
I cooked my car with the last 'aggresive' chipped stock ECU so do not trust the ECU at all having run various JDM tuner ones with no issues for years.........
What sort of power can I expect for hybrid 360deg bearing turbos, Stillen intercoolers, 555's injectors, Intake and exhaust BUT with daily driver reliability???
The ECU is identical to the JDM ones, only the mapping differs.
Mine ran 370 at the wheels for more than 5 years with a pretty much identical setup without any hassle. I do leave the safety maps intact too which is something most aftermarket chips remove.
looks like I'll be giving you a call john my car should be back up and running in a month or so.
I will now have a batch of JDM tuner ECU's that I will be selling off as they are all for stock injector cars:-
1) Mines
2) Tomei
3) Jun
4) Blitz
etc.
Each has its own identity and all are mapped with safety maps etc.
Do you know what is the going rate for these ECU's these days
MInes
