Depends on what you want, hot water solar yes many custermers make them to heat the water for swimming pools
no, a standard electricity one to put power in a garage.
Dont think so much calculaters, but the gearing will have to be worked out, and also the rotor blade, if done by wind will have to be balanced as it will vibrate
Not feasible I don't think - far too complicated manufacturing process.
Electricity no but heating water using solar power is easy enough, a black box with black pipes inside in direct sunlight will absorb the heat, all you need is a little pump to pull the water through into a storage tank
