unknown connector
Just recently purchased a 1991 N/A auto LWB and have began to look over it.
Looking inside my N/A engine compartment from the front on the right hand side under the main induction hose & Fuse box, there is a single connector with a blue wire which is unplugged. Any idea what it does?
I have also have noticed that the aircon belt is missing don't know whether that is anything to do with it?
Is it possible belt was removed because of the aircon is U/S? or did it snap and was never replaced. Or do people remove it gain more efficiency?
that will be the connector for the air con pump try to turn the pump more than likely to be seized
JAMIETT
The pump is not seized but does seem to be a bit rough on turning it. Presumably a you would you just unbolt and replace? or do you have to depressurise first? Are the aircon pumps all the same? i.e TT NA Mk1 & 2 etc
